It is currently Fri Jul 18, 2025 10:31 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
 Post subject: Re: Truss rod trouble!
PostPosted: Thu Nov 28, 2013 1:08 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Filippo Morelli wrote:
I never use silicone. Not sure why it would be necessary. I don't like silicone around anything that is going to be finished, either. You can shim the sides with wood thins (like veneer) and it should be just fine. What I like to do is take a small piece of clear scotch tape and put it over the threaded block and truss rod nut part of the channel. I put the tape on top, then cut it off, leaving just a 1/16-1/8" on the top of the neck (proud of the channel). This keeps any glue out of that area.
On glue up - I would keep that sucker clamped at least 24 hours, preferably 48 hours with any water based glue. This gives an opportunity for the moisture to work its way out while the neck is clamped up. I would also make sure you have plenty of clamp pressure - it's a big joint. Titebond should be just fine.
Make sure you thoroughly clean the fretboard and neck, especially given the silicone ...
Hope something I said helps out!
Filippo
I don't use silicone but I do use a latex type of caulk. I use a few dabs along the slot to help prevent any possible rattle of the rod after glue up.
Another day, another dollar.
PostPosted: Thu Nov 28, 2013 9:30 am
First name: D
Last Name: S
Freeman wrote:
dzsmith wrote:
Sorry for skewing the thread:
Freeman, on your LP build, is the fret board glued to the top plate of the body?
I have been studying LP builds and this is one area I am unsure of.
Dan
Yes, don't know if it right (only electric I've ever built) but its normal to lightly glue the f/b to the top of an acoustic. As you can see in this pictures, the neck tenon is slightly narrower than the fretboard - the wider portion of the heel is where you set the final neck angle. The neck pocket was routed with the 3-1/2 or 4 degree angle (check with your pups and bridge) with the top plate standing slightly proud, like this
Here is a shot of flossing the neck angle to the body - again, I am used to doing this on acoustics so I just followed the same procedure
After the neck is glued in place I brought the top down flush with it, then glued the f/b down. Here is my clamping method, I'm guilty of using the Irwin clamps LOL
I apologize for hijacking your thread with all the pictures - I hope it helps. Also, if you are interested in building a Lester I did a very long build thread on another forum, I'd be happy to point you to it.
Thanks Freeman, I would appreciate a pointer!
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Nov 28, 2013 12:34 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
Hi Mike,
That's got to be better than silicone, eh?
I'm just curious about this rattle thing, as I've never had the issue, with either any of the guitars I own or any that I have made. My experience is that turning the truss rod just enough so it is loaded keeps anything from rattling, at least when the truss rod is installed in a reasonably fitting slot. Is your experience different? What would be rattling and why, I guess I'm wondering ...
Filippo
I am never gonna live this down...
PostPosted: Thu Nov 28, 2013 12:35 pm
First name: Freeman
Last Name: Keller
Dan
Warning, very long thread.
http://www.harmonycentral.com/t5/Electr ... p/31808721
These users thanked the author Freeman for the post: dzsmith (Thu Nov 28, 2013 8:04 pm)
PostPosted: Thu Nov 28, 2013 3:12 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Filippo[/quote]
I am never gonna live this down...[/quote]
No I'm asking seriously. Lots of folks do this. I assume there is a reason, and I've not encountered. Hence why I'm asking Mike. I'm just trying to understand. Not implying anything except my own ignorance!
Filippo[/quote]
oh, I thought I already said it was called out in the installation instructions by stew mac, not silicone per se but caulk, and being that I had an open tube of silicone at hand...
I just did it because I don't have much experience and the company I bought it from said to do it if you were worried about rattles. I don't know if I'm worried about rattles so I erred on the side of caution.
PostPosted: Thu Nov 28, 2013 5:49 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
John, you missed that, in the post where I asked for more detail, I specifically addressed Michael Shaw (userid: Shaw). He his previous post mentioned that he also does this but uses latex caulk instead. Happy for others to reply with thoughts, of course, but I was not specifically addressing you, but Mike...
Filippo
ok, my name was in that thead too, didn't make the distinction...
PostPosted: Fri Nov 29, 2013 6:22 pm
Last Name: Shaw
City: Philadelphia
State: PA
I do it because the instruction for stew Mac rods called for it. Have I expierenced this rattle on dual action truss rods? Yes! Its more of a buzz then an outright rattle. In have in my possession a Garrison guitar that has a removable dual action rod. The rod slides right out when totally relaxed. This guitar has a persistent buzz. I left the rod out and strung her up and the buzz disappeared. Put it back in and it reappears. The rod has a shrink tubing cover on it so its not that its a bare rod. So when I do them I use the caulk as per stew macs instructions....mike
PostPosted: Sat Nov 30, 2013 11:09 pm
Last Name: Shaw
City: Philadelphia
State: PA
No even under tension there is that buzz. I actually tried putting an additional covering of some electrical shrink tubing I have but couldn't get the rod back in with it on. It was a little to thick since it's the black type made for electrical connections.
PostPosted: Wed Dec 04, 2013 3:14 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Double acting truss rods will rattle (buzz). Getting a tight fit up is a good idea. Is that enough? Think of it this way: would you install barbless frets with a two-part tang, no glue, and expect to get good tone and sustain?
Silicone caulk in truss rod channels is not a finishing issue. I do a lot of finishing. I've seen a lot of issues. That's not one of them. I also do a lot of repairs. I fix a lot of buzzing double-action truss rods. To fix them, I inject silicone caulk in the truss rod cavity.
I never use "bathroom" caulk. Most silicone caulks are corrosive--they'll rust your truss rod as they cure (and rust the threads, and make a mess). Any decent industrial supply catalog has non-corrosive silicone caulks. The product I use for injecting into truss rod cavities is a non-corrosive, non-adhesive, low viscosity, catalysed silicone. It will flow in through a 16 gauge needle, set up without air, and not stick to truss rod threads.
I'm not impressed with most of the available double-acting rods. I've had to pull a few fingerboards to fix frozen rods. Looking at the welds on what's available, I'm surprised I haven't had to do that more often.
I like old school, Gibson style rods. (I also like the old Martin T-section reinforcements.) If you opt for a two element rod, get a good fit up, and bed the rod in a non-corrosive silicone caulk.
These users thanked the author Eric Reid for the post (total 2): John Sonksen (Fri Dec 06, 2013 5:42 pm) • nyazzip (Wed Dec 04, 2013 3:23 am)
PostPosted: Wed Dec 04, 2013 3:27 am
City: chicagoland
State: illinois
i just have a hard time thinking about what adding vibration dampening sound insulation(silicone, ie "rubber")does to the end product: good sounding music....no thanks!
PostPosted: Wed Dec 04, 2013 3:17 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Well I glued it back up last wknd, no silicone or caulk this time so I guess I'll see what happens. I left it clamped up for 24 hours, and didn't make any adjustment for 48. Everything seems to be holding fine.
PostPosted: Wed Dec 04, 2013 3:21 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Nyazzip, it was never flooded with silicone, it was just a couple dabs at the end blocks and a tiny bead down the length. It isn't meant to encase the truss rod, just act as a little cushion.
I don't have any problem with the tone or sustain on my first guitar, so I'm not worried about that.
I think from now on though I'll do what worked the first time and just adjust my clamping time. Thanks everyone.
PostPosted: Wed Dec 04, 2013 3:22 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Eric, I appreciate the comment.
PostPosted: Thu Dec 05, 2013 10:41 am
State: AR
I don't think anybody has mentioned the fact that vibration alone (during shipping) can cause
the rods to turn and leave little if any adjustment range.
Easy to set if need be to assure plenty adjustment range by turning both rods.
These users thanked the author Sandywood for the post: John Sonksen (Fri Dec 06, 2013 5:42 pm)
